After some testing, it appears as if I get the best results by splitting my training data into several different groups and training a model for each group.
Currently, I'm doing this with several different process files. This can get tedious quickly.
I would like to have one master process file that learns a model on each group of data (using examplefilter).
My thought was to do this with IOMultipler and IOSelector. I keep getting errors and can't figure out how to configure things correctly.
Below is an example of what I'm trying to do. (Note: this process fails.)
<operator name="CSVExampleSource" class="CSVExampleSource">
<operator name="IOMultiplier" class="IOMultiplier">
<parameter key="io_object" value="ExampleSet"/>
<parameter key="number_of_copies" value="4"/>
<operator name="chain 1" class="OperatorChain" expanded="no">
<operator name="ExampleFilter" class="ExampleFilter">
<operator name="DecisionTree" class="DecisionTree">
<operator name="ModelWriter" class="ModelWriter">
<operator name="IOSelector" class="IOSelector">
<parameter key="select_which" value="2"/>
<operator name="chain 2" class="OperatorChain" expanded="yes">
<operator name="ExampleFilter (2)" class="ExampleFilter">
<operator name="DecisionTree (2)" class="DecisionTree">
<operator name="ModelWriter (2)" class="ModelWriter">
<operator name="IOSelector (2)" class="IOSelector">
<parameter key="select_which" value="3"/>
<operator name="chain 3" class="OperatorChain" expanded="yes">
<operator name="ExampleFilter (3)" class="ExampleFilter">
<operator name="DecisionTree (3)" class="DecisionTree">
<operator name="ModelWriter (3)" class="ModelWriter">
<operator name="IOSelector (3)" class="IOSelector">
<parameter key="select_which" value="4"/>
<operator name="chain 4" class="OperatorChain" expanded="yes">
<operator name="ExampleFilter (4)" class="ExampleFilter">
<operator name="DecisionTree (4)" class="DecisionTree">
<operator name="ModelWriter (4)" class="ModelWriter">
