Hello everyone!
I am trying to understand the process of feature selecion cause i have to explain it throuroughly, so I went to the java code, besides going to the manual of RM.
In the manual you have the explanation of the Forward Selection.
Forward Selection
1. Create an initial population with n individuals where n is the input example
set’s number of attributes. Each individual will use exactly one of the
features.
2. Evaluate the attribute sets and select only the best k.
3. For each of the k attribute sets do: If there are j unused attributes, make
j copies of the attribute set and add exactly one of the previously unused
attributes to the attribute set.
4. As long as the performance improved in the last p iterations go to 2
I am working with SVMWeighting and then apply feature selection, LOOCV, everything works just fine. I am working with microarray data using 7019 attributes (genes) and 108 instances (microarray).
With SVMWeighting I decrease the number of attributes down to 82 attributes and then when applying FS it decreases to 5.
my question regarding the Forward Selection pseudocode is this:
- the "input" for FS is the 108 number of attributes, my question is if in step 1) that means I have 108 individuals when I create the initial population?and that each individual uses only one feature right?
- when i come to step 2) i don't understand what you mean by " Evaluate the attribute sets"? Does it means the program computes all the possible attribute sets?and what do the attribute sets got to do with the individuals?
- in step 3) (and because i don't fully understand step 2)) .... i tried understand with some examples but i don't get the full picture.
If anyone could help, i would really appreciate it
Thanks in advance.
Ana Luísa
