Hai
I have some doubts to ask from you.
When i run my below code in rapid miner i get the error heap space problem.
i have 2GB RAM only and my data set is like 2 regular attributes, 50000 example.
DO i have any other changes to be done to get the result like improve my code / do I need to upgrade my RAM .
<operator name="Root" class="Process" expanded="yes"> <operator name="CSVExampleSource" class="CSVExampleSource"> <parameter key="filename" value="C:\b9.csv"/> </operator> <operator name="Numerical2Polynominal" class="Numerical2Polynominal"> </operator> <operator name="Aggregation" class="Aggregation"> <list key="aggregation_attributes"> <parameter key="item" value="count"/> </list> <parameter key="group_by_attributes" value="tid|item"/> </operator> <operator name="Example2AttributePivoting" class="Example2AttributePivoting"> <parameter key="group_attribute" value="tid"/> <parameter key="index_attribute" value="item"/> </operator> <operator name="ChangeAttributeRole" class="ChangeAttributeRole"> <parameter key="name" value="tid"/> </operator> <operator name="UserBasedDiscretization" class="UserBasedDiscretization"> <list key="classes"> <parameter key="yes" value="1.0"/> <parameter key="no" value="0.0"/> </list> </operator> <operator name="FPGrowth" class="FPGrowth"> <parameter key="min_support" value="0.2"/> </operator> <operator name="AssociationRuleGenerator" class="AssociationRuleGenerator"> <parameter key="keep_frequent_item_sets" value="true"/> <parameter key="min_confidence" value="0.4"/> </operator> <operator name="ResultWriter" class="ResultWriter"> <parameter key="result_file" value="C:\Documents and Settings\svpriyan\Desktop\7to13res.res"/> </operator> </operator>
thanks
Priyan
