for my mixed learning set containing nominal and numerical attributes and a nominal label (yes/no), I was trying to
grid-optimize parameter 'k' of the NearestNeighbor operator. This is the process XML:
<operator name="CSVExampleSource" class="CSVExampleSource">
<parameter key="filename" value="examples.csv"/>
<parameter key="label_name" value="result"/>
<operator name="GridParameterOptimization" class="GridParameterOptimization" expanded="yes">
<list key="parameters">
<parameter key="NearestNeighbors.k" value="[1.0;3.0;3;linear]"/>
</list>
<operator name="XValidation" class="XValidation" expanded="yes">
<parameter key="sampling_type" value="shuffled sampling"/>
<operator name="NearestNeighbors" class="NearestNeighbors">
<parameter key="divergence" value="EuclideanDistance"/>
<parameter key="k" value="2"/>
<parameter key="measure_types" value="MixedMeasures"/>
<parameter key="mixed_measure" value="MixedEuclideanDistance"/>
<parameter key="nominal_measure" value="NominalDistance"/>
<parameter key="numerical_measure" value="EuclideanDistance"/>
<parameter key="weighted_vote" value="true"/>
<operator name="OperatorChain" class="OperatorChain" expanded="yes">
<operator name="ModelApplier" class="ModelApplier">
<list key="application_parameters">
</list>
<operator name="ClassificationPerformance" class="ClassificationPerformance">
<parameter key="absolute_error" value="true"/>
<parameter key="accuracy" value="true"/>
<list key="class_weights">
</list>
<parameter key="classification_error" value="true"/>
Runnig it, RapidMiner terminates with:
Exception: com.rapidminer.example.AttributeTypeException
Message: Cannot map index of nominal attribute to nominal value: index -2147483648 is out of bounds!
Stack trace:
com.rapidminer.example.table.PolynominalMapping.mapIndex(PolynominalMapping.java:112)
com.rapidminer.example.Example.getNominalValue(Example.java:106)
com.rapidminer.operator.performance.MultiClassificationPerformance.countExample(MultiClassificationPerformance.java:191)
com.rapidminer.operator.performance.AbstractPerformanceEvaluator.evaluate(AbstractPerformanceEvaluator.java:366)
com.rapidminer.operator.performance.AbstractPerformanceEvaluator.evaluate(AbstractPerformanceEvaluator.java:297)
com.rapidminer.operator.performance.AbstractPerformanceEvaluator.apply(AbstractPerformanceEvaluator.java:167)
com.rapidminer.operator.Operator.apply(Operator.java:663)
com.rapidminer.operator.OperatorChain.apply(OperatorChain.java:377)
com.rapidminer.operator.validation.ValidationChain.evaluate(ValidationChain.java:251)
com.rapidminer.operator.validation.ValidationChain.evaluate(ValidationChain.java:274)
com.rapidminer.operator.validation.XValidation.estimatePerformance(XValidation.java:143)
com.rapidminer.operator.validation.ValidationChain.apply(ValidationChain.java:219)
com.rapidminer.operator.meta.ParameterOptimizationOperator.getPerformance(ParameterOptimizationOperator.java:82)
com.rapidminer.operator.meta.GridSearchParameterOptimizationOperator.apply(GridSearchParameterOptimizationOperator.java:158)
com.rapidminer.Process.run(Process.java:665)
com.rapidminer.Process.run(Process.java:635)
com.rapidminer.Process.run(Process.java:625)
com.rapidminer.gui.ProcessThread.run(ProcessThread.java:61)
I also got the log message:
G Jan 10, 2009 3:01:34 PM: [Warning] SimpleCriterion: NaN was generated!
Last message repeated 458 times.
G Jan 10, 2009 3:01:34 PM: [Fatal] AttributeTypeException occured in 11th application of ClassificationPerformance (ClassificationPerformance)
G Jan 10, 2009 3:01:34 PM: [Fatal] Process failed: Cannot map index of nominal attribute to nominal value: index -2147483648 is out of bounds!
When I change the range for parameter 'k' to [1..100] the process works fine.
Any ideas what might be wrong or how I can debug it?
Paul
