Tertius problem
edfred
edfred New Altair Community Member
can comebody here give me an example operatorchain for the W-Tertius Algorithm to generate associationrules?
I have tried the following:
   <operator name="TextInput" class="TextInput" expanded="yes">
       <list key="texts">
         <parameter key="test" value="/Users/guest/Documents/tertius/test"/>
       </list>
       <parameter key="vector_creation" value="BinaryOccurrences"/>
       <operator name="StringTokenizer" class="StringTokenizer">
       <operator name="GermanStopwordFilter" class="GermanStopwordFilter">
       <operator name="ToLowerCaseConverter" class="ToLowerCaseConverter">
       <operator name="TokenLengthFilter" class="TokenLengthFilter">
           <parameter key="min_chars" value="3"/>
   <operator name="Numerical2Binominal" class="Numerical2Binominal">
   <operator name="W-Tertius" class="W-Tertius">
...but it isn't working... :(
Best regards
edfred
  • land
    land New Altair Community Member
    Hi Edfred,
    I'm not familiar with this implementation, since it's a WEKA learner. Did you try to use FP-Growth?
    Just to be curious: Why do you generate Association Rules over Text Data?
    Greetings,
      Sebastian
  • edfred
    and thx for ur responds. I have html-sites as input. I convert the Textinput from numerical to binominal data.
    I have done the same data with the Apriori-algorithm and it worked. Only the Tertius-algorithm doesn't work.
    I have to solve the problem with the Tertius-algorithm. I know that I can use other algorithms, but for my task it isn't allowed.
    Thanks anyway
    Edfred
  • edfred
    can somebody explain me this exception, please:
    Error in: W-Tertius (W-Tertius) W-Tertius caused an error: weka.core.UnsupportedAttributeTypeException: weka.associations.Tertius: Cannot handle unary class!
    An external program or library has reported an error. Please see the documentation of this program or library for further information
    This is my operator-chain now:
        <operator name="ExampleSource" class="ExampleSource">
            <parameter key="attributes" value="../Test.aml"/>
        <operator name="AbsoluteSampling" class="AbsoluteSampling">
        <operator name="AttributeFilter" class="AttributeFilter">
            <parameter key="condition_class" value="is_numerical"/>
    Best regards
    Edfred
  • edfred
    Hi at all,
    I have found the problem. You can avoid the Exception with an operator called 'RemoveUselessAttributes'. If you add this operator to your operator tree, the Tertius-algorithm will finish without exceptions and generate association rules.
    Thanks, to all peple who tried to help me.
    Best regards,
    Edfred
  • land
    Hi Edfred,
    thank you for posting this solution. I will try to remember if another user comes up with this problem.
    Greetings,
      Sebastian
