This is a bit of a complicated problem, so I'll do my best to describe it sequentially
I actually want to train two "systems". The second system will learn from the output of the first.
My challenge is how to:
1) Keep all the features in my example set
2) Learn a model on a subset of features
3) Create a NEW ATTRIBUTE with the predicted value
4) Output ALL the features PLUS the new attribute.
This would be fairly easy, except for my need to train a model on a subset of features.
Does anybody have any ideas about how to handle this??
Thanks!
Here is an outline for what I am trying to do:
1) Input is data set with 10 features.
2) I want to perform regression on 8 of the features.
2a) Easy enough with the feature name filter. Just eliminate the two I'm not using for regression. (For example, remove patient's name.)
3) Create the regression model
4) Write out the model
5) Apply the model to the examples
6) Create a NEW example set with the model predicted values AND THE ORIGINAL 10 FEATURES
7) Write the new example set to disk
