earmijo wrote:Ideale:Going thru some of the sample programs provided with RM is very instructive. Take a look at the program 06_Confusion_Matrix.xml that you can find in the directory samples\Validation or 18_SimpleCostSensitiveLearning.xml in the directory samples\Learner. There you will find the answer to your question. I also recommend you go thru the RapidMiner Tutorial available from the menu Help. Best regards,\E
