RapidMiner.init(); Process process = new Process(); try { Operator inputOperator = OperatorService.createOperator(ArffExampleSource.class); inputOperator.setParameter("data_file","C:\\provincias.arff"); process.getRootOperator().addOperator(inputOperator); IOContainer container; try { container = inputOperator.apply(new IOContainer()); ExampleSet exampleSet = container.get(ExampleSet.class); System.out.println("///////////////////////////////////////"); System.out.println("NOW TO NUMERIC"); System.out.println("///////////////////////////////////////"); Operator n2n = OperatorService.createOperator(NominalToNumeric.class); ... ... ...(THE REST OF THE CODE)
G Dec 16, 2008 2:11:13 PM: rapidminer.home is 'C:\eclipse_gan\Workspace\yale'.G Dec 16, 2008 2:11:13 PM: ----------------------------------------------------G Dec 16, 2008 2:11:13 PM: Initialization SettingsG Dec 16, 2008 2:11:13 PM: ----------------------------------------------------G Dec 16, 2008 2:11:13 PM: Default system encoding for IO: windows-1252G Dec 16, 2008 2:11:13 PM: Load core operators...G Dec 16, 2008 2:11:13 PM: Load Weka operators: trueG Dec 16, 2008 2:11:13 PM: Load JDBC drivers from lib directory: trueG Dec 16, 2008 2:11:13 PM: Load JDBC drivers from classpath: falseG Dec 16, 2008 2:11:13 PM: Load plugins: trueG Dec 16, 2008 2:11:13 PM: Load plugins from 'C:\eclipse_gan\Workspace\yale\lib\plugins'G Dec 16, 2008 2:11:13 PM: ----------------------------------------------------G Dec 16, 2008 2:11:13 PM: Read rcfile 'C:\eclipse_gan\Workspace\yale\etc\rapidminerrc'.G Dec 16, 2008 2:11:13 PM: Trying rcfile 'C:\eclipse_gan\Workspace\yale\etc\rapidminerrc.Windows XP'...skippedG Dec 16, 2008 2:11:13 PM: Trying rcfile 'C:\Documents and Settings\jorge.palacio\.rapidminer\4_3_0_rapidminerrc'...skippedG Dec 16, 2008 2:11:13 PM: Read rcfile 'C:\Documents and Settings\jorge.palacio\.rapidminer\4_3_0_rapidminerrc.Windows XP'.G Dec 16, 2008 2:11:13 PM: Trying rcfile 'C:\eclipse_gan\Workspace\Reputacion\rapidminerrc'...skippedG Dec 16, 2008 2:11:13 PM: Trying rcfile 'C:\eclipse_gan\Workspace\Reputacion\rapidminerrc.Windows XP'...skippedG Dec 16, 2008 2:11:13 PM: Trying rapidminer.rcfile. Property not specified...skippedG Dec 16, 2008 2:11:13 PM: Loading operators from 'operators.xml'.G Dec 16, 2008 2:11:19 PM: Loading JDBC driver information from 'etc:jdbc_properties.xml'.///////////////////////////////////////NOW TO NUMERIC///////////////////////////////////////Exception in thread "main" java.lang.NullPointerException at com.rapidminer.operator.OperatorCreationException.createMessage(OperatorCreationException.java:69) at com.rapidminer.operator.OperatorCreationException.<init>(OperatorCreationException.java:53) at com.rapidminer.tools.OperatorService.createOperator(OperatorService.java:567) at ProcessCreator.main(ProcessCreator.java:53)
<operator name = "Nominal2Numeric" class = "com.rapidminer.operator.preprocessing.filter.NominalToNumeric" description = "Maps all values to real values (usually simply using the internal indices)." deprecation = "Please use the operator 'Nominal2Numerical' instead" group = "Preprocessing.Attributes.Filter.Converter"/>
