<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSource" class="ExampleSource"> <parameter key="attributes" value="sample\data\iris.aml"/> </operator> <operator name="XValidation" class="XValidation" expanded="yes"> <operator name="DecisionTree" class="DecisionTree"> </operator> <operator name="OperatorChain" class="OperatorChain" expanded="yes"> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="PerformanceEvaluator" class="PerformanceEvaluator"> <parameter key="accuracy" value="true"/> </operator> </operator> </operator> <operator name="IOObjectWriter" class="IOObjectWriter"> <parameter key="io_object" value="PerformanceVector"/> <parameter key="object_file" value="test.xml"/> <parameter key="output_type" value="XML"/> </operator></operator>
<object-stream> <PerformanceVector id="1"> <currentValues id="2"> <entry> <string>accuracy</string> <double>0.9400000000000001</double> </entry> </currentValues> <comparator class="com.rapidminer.operator.performance.PerformanceVector$DefaultComparator" id="3"/> <mainCriterion>first</mainCriterion> <averagesList id="4"> <kappa id="5"> <counter id="6"> <double-array id="7"> <double>50.0</double> <double>0.0</double> <double>0.0</double> </double-array> <double-array id="8"> <double>0.0</double> <double>45.0</double> <double>5.0</double> </double-array> <double-array id="9"> <double>0.0</double> <double>4.0</double> <double>46.0</double> </double-array> </counter> <classNames id="10"> <string>Iris-setosa</string> <string>Iris-versicolor</string> <string>Iris-virginica</string> </classNames> <classNameMap id="11"> <entry> <string>Iris-virginica</string> <int>2</int> </entry> <entry> <string>Iris-setosa</string> <int>0</int> </entry> <entry> <string>Iris-versicolor</string> <int>1</int> </entry> </classNameMap> <labelAttribute class="PolynominalAttribute" id="12"> <nominalMapping class="PolynominalMapping" id="13"> <symbolToIndexMap id="14"> <entry> <string>Iris-virginica</string> <int>2</int> </entry> <entry> <string>Iris-setosa</string> <int>0</int> </entry> <entry> <string>Iris-versicolor</string> <int>1</int> </entry> </symbolToIndexMap> <indexToSymbolMap id="15"> <string>Iris-setosa</string> <string>Iris-versicolor</string> <string>Iris-virginica</string> </indexToSymbolMap> </nominalMapping> <attributeDescription id="16"> <name>label</name> <valueType>1</valueType> <blockType>1</blockType> <defaultValue>0.0</defaultValue> <index>5</index> </attributeDescription> <transformations id="17"> <com.rapidminer.example.set.AttributeTransformationRemapping id="18"> <overlayedMapping class="PolynominalMapping" reference="13"/> </com.rapidminer.example.set.AttributeTransformationRemapping> </transformations> <statistics class="linked-list" id="19"> <NominalStatistics id="20"> <mode>-1</mode> <maxCounter>0</maxCounter> </NominalStatistics> <UnknownStatistics id="21"> <unknownCounter>0</unknownCounter> </UnknownStatistics> </statistics> <constructionDescription>label</constructionDescription> </labelAttribute> <predictedLabelAttribute class="PolynominalAttribute" id="22"> <nominalMapping class="PolynominalMapping" reference="13"/> <attributeDescription id="23"> <name>prediction(label)</name> <valueType>1</valueType> <blockType>1</blockType> <defaultValue>0.0</defaultValue> <index>6</index> </attributeDescription> <transformations id="24"/> <statistics class="linked-list" id="25"> <NominalStatistics id="26"> <mode>0</mode> <maxCounter>45</maxCounter> <scores id="27"> <long>45</long> <long>45</long> <long>45</long> </scores> </NominalStatistics> <UnknownStatistics id="28"> <unknownCounter>0</unknownCounter> </UnknownStatistics> </statistics> <constructionDescription>prediction(label)</constructionDescription> </predictedLabelAttribute> <type>0</type> <meanSum>9.4</meanSum> <meanSquaredSum>8.84888888888889</meanSquaredSum> <averageCount>10</averageCount> </kappa> </averagesList> <source>PerformanceEvaluator</source> </PerformanceVector>
