<operator name="Root" class="Process" expanded="yes"> <operator name="NominalExampleSetGenerator" class="NominalExampleSetGenerator"> <parameter key="number_of_attributes" value="1"/> </operator> <operator name="ChangeAttributeRole" class="ChangeAttributeRole"> <parameter key="name" value="label"/> </operator> <operator name="Aggregation" class="Aggregation"> <list key="aggregation_attributes"> <parameter key="att1" value="count"/> </list> <parameter key="group_by_attributes" value="label|att1"/> </operator> <operator name="Example2AttributePivoting" class="Example2AttributePivoting"> <parameter key="group_attribute" value="label"/> <parameter key="index_attribute" value="att1"/> </operator></operator>
<operator name="Root" class="Process" expanded="yes"> <operator name="CSVExampleSource" class="CSVExampleSource"> <parameter key="filename" value="c:\list.csv"/> </operator> <operator name="Numerical2Polynominal" class="Numerical2Polynominal"> </operator> <operator name="Aggregation" class="Aggregation"> <list key="aggregation_attributes"> <parameter key="item" value="count"/> </list> <parameter key="group_by_attributes" value="tid|item"/> </operator> <operator name="Example2AttributePivoting" class="Example2AttributePivoting"> <parameter key="group_attribute" value="tid"/> <parameter key="index_attribute" value="item"/> </operator></operator>
