<operator name="Root" class="Process" expanded="yes"> <description text="For many learning tasks, Support Vector Machines are among the best suited learning schemes.They adapt the idea of structural risk minimization and allows for non-linear generalizations with help of kernel functions."/> <operator name="ExampleSource" class="ExampleSource"> <parameter key="attributes" value="../data/polynomial.aml"/> </operator> <operator name="JMySVMLearner" class="JMySVMLearner"> <parameter key="keep_example_set" value="true"/> <parameter key="kernel_degree" value="3"/> <parameter key="kernel_type" value="polynomial"/> </operator> <operator name="ModelApplier" class="ModelApplier"> </operator> <operator name="RegressionPerformance" class="RegressionPerformance"> <parameter key="root_mean_squared_error" value="true"/> </operator></operator>
