Hi there,
I have a quick question. Take for example the following output of FrequencyDiscretization:
q58_B -Infinity <= range3 [4.500 - 0] <= 0.0 <= range1 [-8 - 2.500] <= 2.5 <= range2 [2.500 - 4.500] <= 4.5 <= range5 [0 - 8] <= Infinity
Despite that the ranges are not sorted (which is a bit confusing), range3 is odd to me. Why does it go from 4,5 to 0? And why is it in front and not in line?
And where is range4? Why does range5 start again at 0? So the ranges are overlapping?
Values in field q58_B only go from 1-5 and some missing values.
Could you please give me some hints on how to use this output?
Thanks in advance,
best regards
Jörg
