Patrick wrote:But... is there a way to forward the MySQL stream (containing the PDFs actually) to the TextInput Method of the WVTool and make the WVTool use these fields of the different records as files ? Or do I need to use another method than TextInput to perform this task. Thus in summary: how can I replace the directory or URL input option by a kind of ExampleSet input option ?
<operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="yes"> <parameter key="attribute_name_regex" value="Doc"/> <parameter key="condition_class" value="attribute_name_filter"/> <operator name="Nominal2String" class="Nominal2String"> </operator> </operator>
