In experimenting with computing distance measures I ran into some problems with ExampleSet2SimilarityExampleSet and related operators, that I think is a bug introduced in the RM 4.3 code.
I tried the small example Ingo had posted at
http://rapid-i.com/rapidforum/index.php/topic,151.0.html I could not get that example to run on RM 4.3 (Enterprise Edition), and had to downgrade to RM (EE) 4.2 in order to get it to work.
I know you guys are busy, but if this turns out to be a minor problem and easy to fix, it would be of immense help to me to have a fix for it in CVS.
Thanks!
Keith
