If you want to calculate how import a variable is outside these learning algorithms I suggest the operators "GiniIndexWeighting", "InfoGainWeighting" / "InfoGainRatioWeighting". I personally prefer "InfoGainRatio".
Hi;
You can use the "Weight by Tree Importance" operator on your random forest.
See doc: https://docs.rapidminer.com/studio/operators/modeling/feature_weights/weight_by_forest.html
There are some other candidates that will pop up when you do the search in the operator search bar.
Marinus
