Is it possible to nest ValueSubgroupIterators inside of one another so you can cycle over the values of more than one nominal attribute? The operator info indicates that you can't combine multiple attributes within the definition of a single ValueSubgroupIterator, but it seemed like if you had the attributes separated and nested into their own nodes, it should work.
Here's an example of what I'm trying to do. I want to normalize the data once, before modeling each subgroup separately, and then apply the preprocessing model and regression model to a new example set. The problem is that the preprocessing model disappears when you get to the 2nd nested level of subgroup. So when I try to use ModelGrouper to create a combined model, it fails.
<operator name="ExampleSetGenerator" class="ExampleSetGenerator">
<parameter key="target_function" value="sum"/>
<operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="yes">
<parameter key="attribute_name_regex" value="att1|att2"/>
<parameter key="condition_class" value="attribute_name_filter"/>
<operator name="BinDiscretization" class="BinDiscretization">
<parameter key="number_of_bins" value="3"/>
<operator name="Normalization" class="Normalization">
<parameter key="return_preprocessing_model" value="true"/>
<operator name="ValueSubgroupIterator" class="ValueSubgroupIterator" expanded="yes">
<list key="attributes">
<parameter key="att1" value="all"/>
</list>
<operator name="ValueSubgroupIterator (2)" class="ValueSubgroupIterator" expanded="yes">
<parameter key="att2" value="all"/>
</list>
<operator name="W-LinearRegression" class="W-LinearRegression">
<parameter key="keep_example_set" value="true"/>
<operator name="ModelGrouper" class="ModelGrouper">
<operator name="ExampleSetGenerator (2)" class="ExampleSetGenerator">
<operator name="ModelApplier" class="ModelApplier">
<list key="application_parameters">
</list>
<parameter key="keep_model" value="true"/>
Thanks for any ideas,
Keith
