P Nov 4, 2008 5:10:11 PM: Initialising process setupP Nov 4, 2008 5:10:12 PM: [NOTE] No filename given for result file, using stdout forlogging results!P Nov 4, 2008 5:10:12 PM: Checking properties...P Nov 4, 2008 5:10:12 PM: Properties are ok.P Nov 4, 2008 5:10:12 PM: Checking process setup...P Nov 4, 2008 5:10:12 PM: Inner operators are ok.P Nov 4, 2008 5:10:12 PM: Checking i/o classes...P Nov 4, 2008 5:10:12 PM: i/o classes are ok. Process output: ParameterSet,PerformanceVector.P Nov 4, 2008 5:10:12 PM: Process ok.P Nov 4, 2008 5:10:12 PM: Process initialisedP Nov 4, 2008 5:10:12 PM: [NOTE] Process startsP Nov 4, 2008 5:10:12 PM: Process: Root[0] (Process) +- ExampleSource[0] (ExampleSource) +- ParameterOptimization[0] (EvolutionaryParameterOptimization) +- IteratingPerformanceAverage[0] (IteratingPerformanceAverage) | +- Validation[0] (XValidation) | +- LibSVMLearner[0] (LibSVMLearner) | +- ApplierChain[0] (OperatorChain) | +- Test[0] (ModelApplier) | +- Performance[0] (Performance) +- Log[0] (ProcessLog)P Nov 4, 2008 5:10:13 PM: [Fatal] NullPointerException occured in 2nd application ofLog (ProcessLog)P Nov 4, 2008 5:10:13 PM: [Fatal] Process failed: null Root[1] (Process) +- ExampleSource[1] (ExampleSource) +- ParameterOptimization[1] (EvolutionaryParameterOptimization) +- IteratingPerformanceAverage[1] (IteratingPerformanceAverage) | +- Validation[0] (XValidation) | +- LibSVMLearner[0] (LibSVMLearner) | +- ApplierChain[0] (OperatorChain) | +- Test[0] (ModelApplier) | +- Performance[0] (Performance) here ==> +- Log[1] (ProcessLog)java.lang.NullPointerException atcom.rapidminer.operator.visualization.ProcessLogOperator.fetchAllValues(ProcessLogOperator.java:217) atcom.rapidminer.operator.visualization.ProcessLogOperator.apply(ProcessLogOperator.java:184) at com.rapidminer.operator.Operator.apply(Operator.java:664) atcom.rapidminer.operator.meta.ParameterOptimizationOperator.getPerformance(ParameterOptimizationOperator.java:65) atcom.rapidminer.operator.meta.EvolutionaryParameterOptimizationOperator.setParametersAndEvaluate(EvolutionaryParameterOptimizationOperator.java:277) atcom.rapidminer.operator.meta.ESParameterOptimization.evaluateIndividual(ESParameterOptimization.java:60) atcom.rapidminer.tools.math.optimization.ec.es.ESOptimization.evaluate(ESOptimization.java:386) atcom.rapidminer.tools.math.optimization.ec.es.ESOptimization.optimize(ESOptimization.java:328) atcom.rapidminer.operator.meta.EvolutionaryParameterOptimizationOperator.apply(EvolutionaryParameterOptimizationOperator.java:201) at com.rapidminer.operator.Operator.apply(Operator.java:664) at com.rapidminer.operator.OperatorChain.apply(OperatorChain.java:377) at com.rapidminer.operator.Operator.apply(Operator.java:664) at com.rapidminer.Process.run(Process.java:612) at com.rapidminer.Process.run(Process.java:582) at com.rapidminer.Process.run(Process.java:572) at com.rapidminer.gui.ProcessThread.run(ProcessThread.java:61)
