<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="one third classification"/> </operator> <operator name="IdTagging" class="IdTagging"> </operator> <operator name="IOMultiplier" class="IOMultiplier"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="yes"> <parameter key="attribute_name_regex" value="label|id"/> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="keep_subset_only" value="true"/> <operator name="NoiseGenerator" class="NoiseGenerator"> <parameter key="label_noise" value="0.0"/> <list key="noise"> </list> <parameter key="random_attributes" value="1"/> </operator> <operator name="Sorting" class="Sorting"> <parameter key="attribute_name" value="random"/> </operator> <operator name="IdTagging (2)" class="IdTagging"> </operator> </operator> <operator name="IOSelector" class="IOSelector"> <parameter key="io_object" value="ExampleSet"/> <parameter key="select_which" value="2"/> </operator> <operator name="ExampleSetJoin" class="ExampleSetJoin"> </operator> <operator name="AttributeFilter (2)" class="AttributeFilter"> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="invert_filter" value="true"/> <parameter key="parameter_string" value="random"/> </operator></operator>
<operator name="Root" class="Process" expanded="yes"> <parameter key="random_seed" value="-1"/> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="one third classification"/> </operator> <operator name="RepeatUntilOperatorChain" class="RepeatUntilOperatorChain" expanded="yes"> <parameter key="max_iterations" value="100"/> <operator name="IdTagging" class="IdTagging"> </operator> <operator name="IOMultiplier" class="IOMultiplier"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="no"> <parameter key="attribute_name_regex" value="label|id"/> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="keep_subset_only" value="true"/> <operator name="NoiseGenerator" class="NoiseGenerator"> <parameter key="label_noise" value="0.0"/> <list key="noise"> </list> <parameter key="random_attributes" value="1"/> </operator> <operator name="Sorting" class="Sorting"> <parameter key="attribute_name" value="random"/> </operator> <operator name="IdTagging (2)" class="IdTagging"> </operator> </operator> <operator name="IOSelector" class="IOSelector"> <parameter key="io_object" value="ExampleSet"/> <parameter key="select_which" value="2"/> </operator> <operator name="ExampleSetJoin" class="ExampleSetJoin"> </operator> <operator name="AttributeFilter (2)" class="AttributeFilter"> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="invert_filter" value="true"/> <parameter key="parameter_string" value="random"/> </operator> <operator name="XValidation" class="XValidation" expanded="yes"> <parameter key="leave_one_out" value="true"/> <operator name="NearestNeighbors" class="NearestNeighbors"> <parameter key="k" value="3"/> </operator> <operator name="OperatorChain" class="OperatorChain" expanded="yes"> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="ClassificationPerformance" class="ClassificationPerformance"> <list key="class_weights"> </list> <parameter key="classification_error" value="true"/> </operator> </operator> </operator> </operator></operator>
<operator name="Root" class="Process" expanded="yes"> <parameter key="random_seed" value="-1"/> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="one third classification"/> </operator> <operator name="IteratingPerformanceAverage" class="IteratingPerformanceAverage" expanded="yes"> <operator name="IdTagging" class="IdTagging"> </operator> <operator name="IOMultiplier" class="IOMultiplier"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="yes"> <parameter key="attribute_name_regex" value="label|id"/> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="keep_subset_only" value="true"/> <operator name="NoiseGenerator" class="NoiseGenerator" breakpoints="after"> <parameter key="label_noise" value="0.0"/> <list key="noise"> </list> <parameter key="random_attributes" value="1"/> </operator> <operator name="Sorting" class="Sorting"> <parameter key="attribute_name" value="random"/> </operator> <operator name="IdTagging (2)" class="IdTagging"> </operator> </operator> <operator name="IOSelector" class="IOSelector"> <parameter key="io_object" value="ExampleSet"/> <parameter key="select_which" value="2"/> </operator> <operator name="ExampleSetJoin" class="ExampleSetJoin"> </operator> <operator name="AttributeFilter (2)" class="AttributeFilter"> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="invert_filter" value="true"/> <parameter key="parameter_string" value="random"/> </operator> <operator name="XValidation" class="XValidation" expanded="yes"> <parameter key="leave_one_out" value="true"/> <operator name="NearestNeighbors" class="NearestNeighbors"> <parameter key="k" value="3"/> </operator> <operator name="OperatorChain" class="OperatorChain" expanded="no"> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="ClassificationPerformance" class="ClassificationPerformance"> <list key="class_weights"> </list> <parameter key="classification_error" value="true"/> </operator> </operator> </operator> </operator></operator>
<operator name="Root" class="Process" expanded="yes"> <parameter key="random_seed" value="-1"/> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="one third classification"/> </operator> <operator name="IteratingPerformanceAverage" class="IteratingPerformanceAverage" expanded="yes"> <operator name="IdTagging" class="IdTagging"> </operator> <operator name="IOMultiplier" class="IOMultiplier"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="yes"> <parameter key="attribute_name_regex" value="label|id"/> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="keep_subset_only" value="true"/> <operator name="Permutation" class="Permutation"> </operator> <operator name="IdTagging (2)" class="IdTagging"> </operator> </operator> <operator name="IOSelector" class="IOSelector"> <parameter key="io_object" value="ExampleSet"/> <parameter key="select_which" value="2"/> </operator> <operator name="ExampleSetJoin" class="ExampleSetJoin"> </operator> <operator name="XValidation" class="XValidation" expanded="yes"> <parameter key="leave_one_out" value="true"/> <operator name="NearestNeighbors" class="NearestNeighbors"> <parameter key="k" value="3"/> </operator> <operator name="OperatorChain" class="OperatorChain" expanded="no"> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="ClassificationPerformance" class="ClassificationPerformance"> <list key="class_weights"> </list> <parameter key="classification_error" value="true"/> </operator> </operator> </operator> </operator></operator>
