GC overhead limit exceeded
New Altair Community Member
Updated by Jocelyn
for an extensive GridParameterOptimization, RapidMiner terminates after
a while with:
OutOfMemoryError
Process failed Message:
How can I fix this problem?
More memory for the JVM is not possible since all my 4GB are already
used.
On
http://java.sun.com/javase/technologies/hotspot/gc/gc_tuning_6.html#par_gc.oom
I found that with the option "-XX:-UseGCOverheadLimit" this error can be
avoided. Is this a good solution?
Or should I try to integrate the MemoryCleanUp operator into my model (which
is very simular to sample 11 in the meta validation directory).
Best regards,
Sascha
a while with:
OutOfMemoryError
used.
On
Best regards,
Sascha
1 - 2 of
21
If your app has a lot of concurrent procceses, or it uses a lot of recursion, you should take a look at the Concurrent Collector ..
Here you'll find a lot of information about it http://java.sun.com/javase/technologies/hotspot/gc/gc_tuning_6.html#par_gc.oom
If you have multiple proccessors, then the Concurrent Collector may be very helpful here ..
Hope this helps ..
C ya
