"Plotting sample OperatorEnabler"
Legacy User
I'm just playing around with the meta example
06_OperatorEnabler. After finishing, the plot view
occurs at my display. Can someone tell me what
setting for plotter, x- and y-axis make sense to
interprete the results? :-)
I was trying different combinations but got no
meaningful plots. Or should no useful results be
expected for this artificial example?
Martin
Sampling
land
Hi Martin,
you should select enable_normalization on the x-axis and then select performance as value to plot.
Then the x-axis should show 2 values: False and True. The points above will show the performance if normalization is enabled or not.
Greetings,
Sebastian
Legacy User
Hi Sebastian,
however, when I follow your advices, I get a vertical line for the performance
(parallel to the x-axis) that goes through 0. So, this mean that enable_normalization
had no influence on the performance (for true and false the performance is 0).
This is a little bit strange and that's why I was asking. :-)
Or did I get something wrong?
Martin
IngoRM
I have attached the plotter (please note that this is one of the new scatter plotter of the new 4.3 release) with its settings to this post. You can see that enabling the normalization has an effect on the performance which will be slightly improved.
Cheers,
Ingo
[attachment deleted by admin]
