<operator name="AttributeWeightSelection" class="AttributeWeightSelection"> </operator> <operator name="W-J48 (2)" class="W-J48"> </operator>
<operator name="Root" class="Process" expanded="yes"> <operator name="FeatureSelection" class="FeatureSelection" expanded="no"> <operator name="FSXValidation" class="XValidation" expanded="no"> <parameter key="sampling_type" value="shuffled sampling"/> <operator name="W-J48" class="W-J48"> </operator> <operator name="FSOperatorChain" class="OperatorChain" expanded="yes"> <operator name="FSModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="ClassificationPerformance" class="ClassificationPerformance"> <parameter key="accuracy" value="true"/> <list key="class_weights"> </list> <parameter key="classification_error" value="true"/> <parameter key="kappa" value="true"/> <parameter key="spearman_rho" value="true"/> <parameter key="weighted_mean_precision" value="true"/> <parameter key="weighted_mean_recall" value="true"/> </operator> <operator name="FSMinMaxWrapper" class="MinMaxWrapper"> <parameter key="minimum_weight" value="0.5"/> </operator> </operator> </operator> </operator> <operator name="AttributeWeightSelection" class="AttributeWeightSelection"> </operator> <operator name="W-J48 (2)" class="W-J48"> </operator></operator>
