<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSource" class="ExampleSource"> <parameter key="attributes" value="iris.aml"/> </operator> <operator name="IOMultiplier" class="IOMultiplier"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="ExampleFilter" class="ExampleFilter"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="a1>5"/> </operator> <operator name="IOSelector" class="IOSelector"> <parameter key="io_object" value="ExampleSet"/> <parameter key="select_which" value="2"/> </operator> <operator name="ExampleFilter (2)" class="ExampleFilter"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="invert_filter" value="true"/> <parameter key="parameter_string" value="a1>5"/> </operator></operator>
Another question is if I have a double[] which has the same structure as e1, e2 etc., how can I add the double[] to eset.
