Posted in SourceForge forum at
http://sourceforge.net/forum/forum.php?thread_id=2185902&forum_id=390413:
Does anybody have any example/project they are willing to share showing the
use of one-class libSVM; I've been playing around with rapidminer for the past
day (which is amazing btw-- tnx!) but using the one-class and modifying any
of the parameters (gamma, coef, C, nu, etc.) does not affect the classification
result which is 100%. I've even modified the data on purpose (to mess it up)
and no luck on seeing any changes.
I've also exported the data (as an arff file) and imported it in to Weka and
the results were more reasonable (changing gamma from 0.01 to 0.07 changed the
classification correctness to ~88%). (This might be off topic, but if anybody
knows how to do PCA on one-class data set in Weka that would be also helpful)
Here is the simplified model xml file:
<parameter key="logfile" value="/home/d/rm_workspace/log.log"/>
<parameter key="resultfile" value="/home/d/rm_workspace/results.res"/>
<operator name="ArffExampleSource" class="ArffExampleSource">
<parameter key="data_file" value="file.arff"/>
<parameter key="label_attribute" value="class"/>
<operator name="Normalization" class="Normalization">
<parameter key="min" value="-1.0"/>
<operator name="PCA" class="PCA">
<operator name="XValidation" class="XValidation" expanded="yes">
<operator name="LibSVMLearner" class="LibSVMLearner">
<parameter key="cache_size" value="150"/>
<list key="class_weights">
</list>
<parameter key="coef0" value="0.03125"/>
<parameter key="confidence_for_multiclass" value="false"/>
<parameter key="degree" value="1"/>
<parameter key="gamma" value="0.01"/>
<parameter key="nu" value="9.765625E-4"/>
<parameter key="svm_type" value="one-class"/>
<operator name="OperatorChain" class="OperatorChain" expanded="yes">
<operator name="ModelApplier (2)" class="ModelApplier">
<list key="application_parameters">
</list>
<operator name="Performance" class="Performance">
Any help is very much appreciated! Thanks!
