Problem with DatabaseExampleSetWriter
Hi Ingo, Hi All,
I have a problem with the operator DatabaseExampleSetWriter. I tried an experiment where I want to "merge" (neither Join, nor Merge, nor anything else) two examplesets outside RM with raw SQL handling.
For that, I installed mySQL and WampServer on a standalone PC. I have verified access rights on a database I have created, called "travail_rapidminer". With or without password, RM does not seem to access this database properly, as I asked it to overwrite output exampleset onto it.
Here is my XML process code :
http://www.mediafire.com/?dummdgmlnm8
and the error box :
http://www.mediafire.com/?tplmnymxxiy
At last, here are my settings on database side :
http://i33.tinypic.com/t9f5tf.jpg
And here is the dialog box that appears before the error box at running :
http://i37.tinypic.com/10y2gwn.jpg
I precise that passwords are coherent, despite the XML experiment does not seem so on this point. Is it a bug, or did I misuse the operator ?
Cheers,
Jean-Charles.
and the error box :
Cheers,
Jean-Charles.
hmm, I must admit that I don't have any clue right now what causes this problem. Did you try if reading from this database works well? The error occurs at a place which actually does not have anything to do which is specific to RM - it directly occurs at the place where the connection is constructed and there is no specific magic done. So I would still assume that there could be an error at the settings. Here is the relevant parts: Some questions:
1. did reading from this database works with these settings?
2. port 80 is rather unusual for a database - the default for mySQL is 3306 if I am not mistaken
3. the user name root@localhost is also unusual - did you try "root" alone?
Sorry, I have no other ideas right now.
Cheers,
Ingo
