<operator name="Root" class="Process" expanded="yes"> <parameter key="logverbosity" value="status"/> <operator name="ExcelExampleSource" class="ExcelExampleSource" breakpoints="after"> <parameter key="excel_file" value="C:\Documents and Settings\BRENT\My Documents\rm_workspace\Training data\RM training ^GSPC v01.xls"/> <parameter key="first_row_as_names" value="true"/> <parameter key="id_column" value="1"/> <parameter key="label_column" value="2"/> </operator> <operator name="GridParameterOptimization" class="GridParameterOptimization" expanded="yes"> <list key="parameters"> <parameter key="LibSVMLearner.C" value="[0.0;20.0;4;linear]"/> </list> <operator name="SlidingWindowValidation" class="SlidingWindowValidation" expanded="yes"> <parameter key="test_window_width" value="60"/> <parameter key="training_window_width" value="240"/> <operator name="LibSVMLearner" class="LibSVMLearner"> <parameter key="C" value="20.0"/> <list key="class_weights"> </list> <parameter key="gamma" value="1.0"/> </operator> <operator name="OperatorChain" class="OperatorChain" expanded="yes"> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="BinominalClassificationPerformance" class="BinominalClassificationPerformance"> <parameter key="f_measure" value="true"/> <parameter key="false_negative" value="true"/> <parameter key="false_positive" value="true"/> <parameter key="main_criterion" value="f_measure"/> <parameter key="precision" value="true"/> <parameter key="recall" value="true"/> <parameter key="true_negative" value="true"/> <parameter key="true_positive" value="true"/> </operator> </operator> </operator> <operator name="ProcessLog" class="ProcessLog"> <list key="log"> <parameter key="precision" value="operator.BinominalClassificationPerformance.value.precision"/> <parameter key="recall" value="operator.BinominalClassificationPerformance.value.recall"/> <parameter key="f measure" value="operator.BinominalClassificationPerformance.value.f_measure"/> <parameter key="TP" value="operator.BinominalClassificationPerformance.value.true_positive"/> <parameter key="FP" value="operator.BinominalClassificationPerformance.value.false_positive"/> <parameter key="TN" value="operator.BinominalClassificationPerformance.value.true_negative"/> <parameter key="FN" value="operator.BinominalClassificationPerformance.value.false_negative"/> <parameter key="SVM - C" value="operator.LibSVMLearner.parameter.C"/> <parameter key="SVM - gamma" value="operator.LibSVMLearner.parameter.gamma"/> </list> </operator> </operator></operator>
<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="number_examples" value="1140"/> <parameter key="number_of_attributes" value="1"/> <parameter key="target_function" value="sum classification"/> </operator> <operator name="NoiseGenerator" class="NoiseGenerator"> <list key="noise"> </list> <parameter key="random_attributes" value="1"/> </operator> <operator name="GridParameterOptimization" class="GridParameterOptimization" expanded="yes"> <list key="parameters"> <parameter key="LibSVMLearner.C" value="[0.0;20.0;4;linear]"/> </list> <operator name="OperatorChain (2)" class="OperatorChain" expanded="yes"> <operator name="SlidingWindowValidation" class="SlidingWindowValidation" expanded="yes"> <parameter key="test_window_width" value="60"/> <parameter key="training_window_width" value="240"/> <operator name="LibSVMLearner" class="LibSVMLearner"> <parameter key="C" value="20.0"/> <list key="class_weights"> </list> <parameter key="gamma" value="1.0"/> </operator> <operator name="OperatorChain" class="OperatorChain" expanded="yes"> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="BinominalClassificationPerformance" class="BinominalClassificationPerformance"> <parameter key="f_measure" value="true"/> <parameter key="main_criterion" value="f_measure"/> <parameter key="precision" value="true"/> <parameter key="recall" value="true"/> </operator> </operator> </operator> <operator name="ProcessLog" class="ProcessLog"> <list key="log"> <parameter key="precision" value="operator.SlidingWindowValidation.value.performance1"/> <parameter key="recall" value="operator.SlidingWindowValidation.value.performance2"/> <parameter key="f measure" value="operator.SlidingWindowValidation.value.performance"/> <parameter key="SVM - C" value="operator.LibSVMLearner.parameter.C"/> <parameter key="SVM - gamma" value="operator.LibSVMLearner.parameter.gamma"/> </list> </operator> </operator> </operator></operator>
By the way, how do I copy the xml into a window like I see in other posts?
