(ExampleCSVSource gives an error complaining that there are different columns in line...)
mierswa wrote:in the AttributeEditor, you can define which rows should be shown and press the Update button in the panel on the left. You could of course also simply load the data and see if all data is there. Just run the process and check the meta data view and the data view.
mierswa wrote:If you have missing values in this data set at the end of the lines I would suggest upgrading to RapidMiner 4.2 since there was a bug for previous versions ignoring missing values at the end of lines in CSV files.
