<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="number_examples" value="200"/> <parameter key="number_of_attributes" value="2"/> <parameter key="target_function" value="checkerboard classification"/> </operator> <operator name="ParameterOptimization" class="GridParameterOptimization" expanded="yes"> <list key="parameters"> <parameter key="NearestNeighbors.k" value="[1.0;3.0;2;linear]"/> </list> <operator name="Validation" class="XValidation" expanded="yes"> <parameter key="sampling_type" value="shuffled sampling"/> <operator name="NearestNeighbors" class="NearestNeighbors"> <parameter key="k" value="3"/> </operator> <operator name="ApplierChain" class="OperatorChain" expanded="yes"> <operator name="Test" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="ClassificationPerformance" class="ClassificationPerformance"> <parameter key="accuracy" value="true"/> <list key="class_weights"> </list> </operator> </operator> </operator> <operator name="Log" class="ProcessLog"> <parameter key="filename" value="paraopt.log"/> <list key="log"> <parameter key="k" value="operator.NearestNeighbors.parameter.k"/> <parameter key="Accuracy" value="operator.Validation.value.performance"/> </list> </operator> </operator></operator>
P.S.: Didn't older RM versions have more similarity measures for the kNN learner?
