<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSource" class="ExampleSource"> <parameter key="attributes" value="iris.aml"/> </operator> <operator name="Aggregation" class="Aggregation"> <parameter key="aggregation_attribute" value="a1"/> <parameter key="group_by_attribute" value="label"/> <parameter key="keep_example_set" value="false"/> </operator></operator>
java.lang.ClassCastException: com.rapidminer.parameter.ParameterTypeStringCategory cannot be cast to com.rapidminer.parameter.ParameterTypeCategory
<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSource" class="ExampleSource"> <parameter key="attributes" value="iris.aml"/> </operator> <operator name="ParameterIteration" class="ParameterIteration" expanded="yes"> <list key="parameters"> </list> <operator name="Aggregation" class="Aggregation"> <parameter key="aggregation_attribute" value="a1"/> <parameter key="group_by_attribute" value="label"/> <parameter key="keep_example_set" value="false"/> </operator> </operator></operator>
<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSource" class="ExampleSource"> <parameter key="attributes" value="sample/data/iris.aml"/> </operator> <operator name="ChangeAttributeRole" class="ChangeAttributeRole"> <parameter key="name" value="label"/> </operator> <operator name="Aggregation" class="Aggregation"> <list key="aggregation_attributes"> <parameter key="a1" value="average"/> <parameter key="a2" value="average"/> <parameter key="a3" value="average"/> <parameter key="a4" value="average"/> </list> <parameter key="keep_example_set" value="false"/> </operator></operator>
<operator name="FeatureGeneration" class="FeatureGeneration"> <list key="functions"> <parameter key="average" value="/(+(att1,+(att2,att3)),const[3]())"/> </list> <parameter key="keep_all" value="true"/> </operator>
