<operator name="Root" class="Process"> <operator name="DatabaseExampleSource" class="DatabaseExampleSource"> <parameter key="database_system" value="Oracle"/> <parameter key="database_url" value="jdbc:oracle:thin:@*******:1521:***"/> <parameter key="password" value="***"/> <parameter key="query" value="SELECT JH_JOBNUMBER, DEVFROMMEAN FROM ( SELECT JH_JOBNUMBER, (CD_VALUE-AVG(CD_VALUE) OVER(PARTITION BY JH_JOBNUMBER, FEATURE_SIZE, ORIENTATION)) AS DEVFROMMEAN FROM ( SELECT JH_JOBNUMBER, CD_FEATURENAME, CASE WHEN CD_FEATURENAME LIKE '%280%' THEN '280' WHEN CD_FEATURENAME LIKE '%400%' THEN '400' END AS FEATURE_SIZE, CASE WHEN CD_FEATURENAME LIKE '%X%' THEN 'X' WHEN CD_FEATURENAME LIKE '%Y%' THEN 'Y' END AS ORIENTATION, CD_VALUE FROM DIM_GENERAL_JOBHEADER header, DIM_CDFEATURE feature, FACT_CDRAWANDLER fact WHERE header.DIM_JH_SK = fact.DIM_JH_SK AND feature.DIM_CDFEATURE_SK = fact.DIM_CDFEATURE_SK AND CD_FEATURENAME LIKE '%_GCD_%' ORDER BY JH_JOBNUMBER, FEATURE_SIZE, ORIENTATION, FLOOR((fact.CD_MEASUREMENTPOINTCOORDINATEY+76200)/10500) DESC, (fact.CD_MEASUREMENTPOINTCOORDINATEX+76200) ) ) -- WHERE DEVFROMMEAN > -30 AND DEVFROMMEAN < 30"/> <parameter key="username" value="***"/> </operator></operator>
P Jun 24, 2008 9:54:32 PM: Initialising process setupP Jun 24, 2008 9:54:32 PM: [NOTE] No filename given for result file, using stdout for logging results!P Jun 24, 2008 9:54:32 PM: Checking properties...P Jun 24, 2008 9:54:32 PM: Properties are ok.P Jun 24, 2008 9:54:32 PM: Checking process setup...P Jun 24, 2008 9:54:32 PM: Inner operators are ok.P Jun 24, 2008 9:54:32 PM: Checking i/o classes...P Jun 24, 2008 9:54:32 PM: i/o classes are ok. Process output: ExampleSet.P Jun 24, 2008 9:54:32 PM: Process ok.P Jun 24, 2008 9:54:32 PM: Process initialisedP Jun 24, 2008 9:54:32 PM: [NOTE] Process startsP Jun 24, 2008 9:54:32 PM: Process: Root[0] (Process) +- DatabaseExampleSource[0] (DatabaseExampleSource)P Jun 24, 2008 9:54:50 PM: [NOTE] Process finished after 18 secondsP Jun 24, 2008 9:54:50 PM: Process: Root[1] (Process) +- DatabaseExampleSource[1] (DatabaseExampleSource)P Jun 24, 2008 9:54:50 PM: Produced output:IOContainer (1 objects):SimpleExampleSet:134424 examples,2 regular attributes,no special attributes(created by DatabaseExampleSource)P Jun 24, 2008 9:54:50 PM: [NOTE] Process finished successfullyG Jun 24, 2008 9:54:50 PM: [Error] Plotter: the given data contains missing values. Probably most plotters will not be able to produce proper visualizations. Please replace missing values beforehand if possible.G Jun 24, 2008 9:54:50 PM: [Warning] Cannot plot all data points, using only a sample of 1000 rows.G Jun 24, 2008 9:54:51 PM: [NOTE] Cannot use plotter 'Scatter 3D': Data table is not allowed to contain missing values. Please replace them beforehand.G Jun 24, 2008 9:54:52 PM: [NOTE] Cannot use plotter 'Scatter 3D Color': Data table is not allowed to contain missing values. Please replace them beforehand.G Jun 24, 2008 9:54:52 PM: [NOTE] Cannot use plotter 'SOM': Data table is not allowed to contain missing values. Please replace them beforehand.G Jun 24, 2008 9:54:52 PM: [NOTE] Cannot use plotter 'Density': Data table is not allowed to contain missing values. Please replace them beforehand.G Jun 24, 2008 9:54:52 PM: [NOTE] Cannot use plotter 'Sticks 3D': Data table is not allowed to contain missing values. Please replace them beforehand.G Jun 24, 2008 9:54:52 PM: [NOTE] Cannot use plotter 'Box 3D': Data table is not allowed to contain missing values. Please replace them beforehand.G Jun 24, 2008 9:54:52 PM: [NOTE] Cannot use plotter 'Surface 3D': Data table must have between 0 and 50 rows, was 1000.
<operator name="Root" class="Process" expanded="yes"> <operator name="DatabaseExampleSource" class="DatabaseExampleSource"> <parameter key="database_system" value="Oracle"/> <parameter key="database_url" value="jdbc:oracle:thin:@*******:1521:***"/> <parameter key="password" value="***"/> <parameter key="query" value="SELECT JH_JOBNUMBER, DEVFROMMEAN FROM ( SELECT JH_JOBNUMBER, (CD_VALUE-AVG(CD_VALUE) OVER(PARTITION BY JH_JOBNUMBER, FEATURE_SIZE, ORIENTATION)) AS DEVFROMMEAN FROM ( SELECT JH_JOBNUMBER, CD_FEATURENAME, CASE WHEN CD_FEATURENAME LIKE '%280%' THEN '280' WHEN CD_FEATURENAME LIKE '%400%' THEN '400' END AS FEATURE_SIZE, CASE WHEN CD_FEATURENAME LIKE '%X%' THEN 'X' WHEN CD_FEATURENAME LIKE '%Y%' THEN 'Y' END AS ORIENTATION, CD_VALUE FROM DIM_GENERAL_JOBHEADER header, DIM_CDFEATURE feature, FACT_CDRAWANDLER fact WHERE header.DIM_JH_SK = fact.DIM_JH_SK AND feature.DIM_CDFEATURE_SK = fact.DIM_CDFEATURE_SK AND CD_FEATURENAME LIKE '%_GCD_%' ORDER BY JH_JOBNUMBER, FEATURE_SIZE, ORIENTATION, FLOOR((fact.CD_MEASUREMENTPOINTCOORDINATEY+76200)/10500) DESC, (fact.CD_MEASUREMENTPOINTCOORDINATEX+76200) ) ) -- WHERE DEVFROMMEAN > -30 AND DEVFROMMEAN < 30"/> <parameter key="username" value="***"/> </operator></operator>
P Jun 24, 2008 10:15:23 PM: Initialising process setupP Jun 24, 2008 10:15:23 PM: [NOTE] No filename given for result file, using stdout for logging results!P Jun 24, 2008 10:15:23 PM: Checking properties...P Jun 24, 2008 10:15:23 PM: Properties are ok.P Jun 24, 2008 10:15:23 PM: Checking process setup...P Jun 24, 2008 10:15:23 PM: Inner operators are ok.P Jun 24, 2008 10:15:23 PM: Checking i/o classes...P Jun 24, 2008 10:15:23 PM: i/o classes are ok. Process output: ExampleSet.P Jun 24, 2008 10:15:23 PM: Process ok.P Jun 24, 2008 10:15:23 PM: Process initialisedP Jun 24, 2008 10:15:23 PM: [NOTE] Process startsP Jun 24, 2008 10:15:23 PM: Process: Root[0] (Process) +- DatabaseExampleSource[0] (DatabaseExampleSource)G Jun 24, 2008 10:15:28 PM: [Error] While reading examples from result set: operation not allowed: Unsupported syntax for refreshRow()P Jun 24, 2008 10:15:28 PM: [NOTE] Process finished after 5 secondsP Jun 24, 2008 10:15:28 PM: Process: Root[1] (Process) +- DatabaseExampleSource[1] (DatabaseExampleSource)P Jun 24, 2008 10:15:28 PM: Produced output:IOContainer (1 objects):SimpleExampleSet:10 examples,2 regular attributes,no special attributes(created by DatabaseExampleSource)P Jun 24, 2008 10:15:28 PM: [NOTE] Process finished successfully
P Jun 24, 2008 10:15:59 PM: Initialising process setupP Jun 24, 2008 10:15:59 PM: [NOTE] No filename given for result file, using stdout for logging results!P Jun 24, 2008 10:15:59 PM: Checking properties...P Jun 24, 2008 10:15:59 PM: Properties are ok.P Jun 24, 2008 10:15:59 PM: Checking process setup...P Jun 24, 2008 10:15:59 PM: Inner operators are ok.P Jun 24, 2008 10:15:59 PM: Checking i/o classes...P Jun 24, 2008 10:15:59 PM: i/o classes are ok. Process output: ExampleSet.P Jun 24, 2008 10:15:59 PM: Process ok.P Jun 24, 2008 10:15:59 PM: Process initialisedP Jun 24, 2008 10:15:59 PM: [NOTE] Process startsP Jun 24, 2008 10:15:59 PM: Process: Root[1] (Process) +- DatabaseExampleSource[1] (DatabaseExampleSource)P Jun 24, 2008 10:16:06 PM: [NOTE] Process finished after 6 secondsP Jun 24, 2008 10:16:06 PM: Process: Root[1] (Process) +- DatabaseExampleSource[1] (DatabaseExampleSource)P Jun 24, 2008 10:16:06 PM: Produced output:IOContainer (1 objects):SimpleExampleSet:10 examples,2 regular attributes,no special attributes(created by DatabaseExampleSource)P Jun 24, 2008 10:16:06 PM: [NOTE] Process finished successfully
