<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="simple polynomial classification"/> </operator> <operator name="ParameterIteration" class="ParameterIteration" expanded="yes"> <parameter key="keep_output" value="true"/> <list key="parameters"> <parameter key="OperatorSelector.select_which" value="1,2"/> </list> <operator name="OperatorSelector" class="OperatorSelector" expanded="yes"> <parameter key="select_which" value="2"/> <operator name="ExampleFilter" class="ExampleFilter"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="att1>0"/> </operator> <operator name="ExampleFilter (2)" class="ExampleFilter"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="att1<0"/> </operator> </operator> </operator></operator>
