Attr1 == 4
<operator name="Root" class="Process" expanded="yes"> <operator name="NominalExampleSetGenerator" class="NominalExampleSetGenerator"> </operator> <operator name="Aggregation" class="Aggregation"> <list key="aggregation_attributes"> <parameter key="att1" value="count"/> </list> <parameter key="group_by_attributes" value="att1"/> </operator> <operator name="IOSelector" class="IOSelector"> <parameter key="io_object" value="ExampleSet"/> <parameter key="select_which" value="2"/> </operator> <operator name="ChangeAttributeRole" class="ChangeAttributeRole"> <parameter key="name" value="att1"/> <parameter key="target_role" value="id"/> </operator> <operator name="IOSelector (2)" class="IOSelector"> <parameter key="io_object" value="ExampleSet"/> <parameter key="select_which" value="2"/> </operator> <operator name="ChangeAttributeRole (2)" class="ChangeAttributeRole"> <parameter key="name" value="att1"/> <parameter key="target_role" value="id"/> </operator> <operator name="ExampleSetJoin" class="ExampleSetJoin"> </operator></operator>
