<parameter key="young" value="18.0"/> <parameter key="midage" value="40.0"/> <parameter key="old" value="2000.0"/>
Contemno wrote:Thx for your answer.Unfortunately it's not working as it should be.When I use the knot Nominal2Numeric the values are changed completely.A "48" maybe is changed to a "1". (not the mentioned recoding)The problem is that without this knot the recoding isn't done on this value.
Contemno wrote:A second problem accured. How can I delete rows with missing values. Incomplete ones in other words.
Contemno wrote:You told me to use AttributeSubsetPreprocessing, to select the attributes I need to process changes on.But this knot is only able to selct one attribute. Isn't it?Maybe there is a possibility to define more than one atrribute in "attribute_name_regex"?I need to define the attributes by name wich the following is processed on.
If you want e.g. to apply the inner operators on say two attributes called age and weight, the corresponding regular expression which lets you chose these attributes is age|weight .
