I use custom ID values for each record in my database. StringTextInput discards these ID values and the ID attribute name and inserts its own attribute name and Id value.
Is there a way to keep my original ID values? I notice the new ID values do not match the original records and I can not match my records to cluster results. See step 3 in the screen capture to see how these change.
<description text="#ylt#h3#ygt#Specifying texts by an example
set#ylt#/h3#ygt##ylt#p#ygt#Using the parameter list or the wizard are simple methods for
setting up the directories from which the text documents are read. Sometimes, however, a
more flexible solution is needed. If, for instance, your text documents have different types
of encoding or are written in different languages, you might wish to provide this
information for each input directory separately.#ylt#/p#ygt# #ylt#p#ygt#You can do this by
using an example set that contains one row for each input directory and corresponding
attributes for source, encoding, type and class. If such an example set is provided, the
texts in the parameter list are ignored.#ylt#/p#ygt#"/>
<operator name="DatabaseExampleSource" class="DatabaseExampleSource">
<parameter key="database_system" value="Microsoft SQL Server (JTDS)"/>
<parameter key="database_url" value="jdbc:jtds:sqlserver://localhost:1433/xxx"/>
<parameter key="id_attribute" value="RecID"/>
<parameter key="password" value="qqqqq"/>
<parameter key="query" value="SELECT * FROM [tblGolfTest]"/>
<parameter key="username" value="sa"/>
<operator name="ExampleVisualizer (Step1)" class="ExampleVisualizer"
breakpoints="before">
<operator name="StringTextInput" class="StringTextInput" expanded="yes">
<parameter key="filter_nominal_attributes" value="true"/>
<list key="namespaces">
</list>
<operator name="StringTokenizer" class="StringTokenizer">
<operator name="ExampleVisualizer (Step2)" class="ExampleVisualizer"
[attachment deleted by admin]
