Finally: where can I find a list of function such as +, *, sin, conversion functions...
mierswa wrote:Hi,since you already found the operator Numeric2Polynominal I am assuming that you have something different in mind. Could you give a small example what you want to achieve? I am not sure if I totally got your point.
select brand, fami, sum(vend) as totvend from tab1 group by brand, fami
<operator name="Root" class="Process" expanded="yes"> <operator name="DataGeneration" class="OperatorChain" expanded="no"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="attributes_lower_bound" value="10.0"/> <parameter key="attributes_upper_bound" value="50.0"/> <parameter key="number_of_attributes" value="3"/> <parameter key="target_function" value="sum"/> </operator> <operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="yes"> <parameter key="attribute_name_regex" value="att2||att3"/> <operator name="BinDiscretization" class="BinDiscretization"> <parameter key="use_long_range_names" value="false"/> </operator> </operator> <operator name="ChangeAttributeName" class="ChangeAttributeName"> <parameter key="new_name" value="brand"/> <parameter key="old_name" value="att2"/> </operator> <operator name="AttributeValueMapper" class="AttributeValueMapper"> <parameter key="attributes" value="brand"/> <parameter key="replace_by" value="brand1"/> <parameter key="replace_what" value="range1"/> </operator> <operator name="AttributeValueMapper (2)" class="AttributeValueMapper"> <parameter key="attributes" value="brand"/> <parameter key="replace_by" value="brand2"/> <parameter key="replace_what" value="range2"/> </operator> <operator name="ChangeAttributeName (2)" class="ChangeAttributeName"> <parameter key="new_name" value="fami"/> <parameter key="old_name" value="att3"/> </operator> <operator name="AttributeValueMapper (3)" class="AttributeValueMapper"> <parameter key="attributes" value="fami"/> <parameter key="replace_by" value="fami1"/> <parameter key="replace_what" value="range1"/> </operator> <operator name="AttributeValueMapper (4)" class="AttributeValueMapper"> <parameter key="attributes" value="fami"/> <parameter key="replace_by" value="fami2"/> <parameter key="replace_what" value="range2"/> </operator> <operator name="ChangeAttributeName (3)" class="ChangeAttributeName"> <parameter key="new_name" value="vend"/> <parameter key="old_name" value="att1"/> </operator> <operator name="FeatureNameFilter" class="FeatureNameFilter"> <parameter key="filter_special_features" value="true"/> <parameter key="skip_features_with_name" value="label"/> </operator> </operator> <operator name="AttributeMerge" class="AttributeMerge"> <parameter key="first_attribute" value="brand"/> <parameter key="second_attribute" value="fami"/> </operator> <operator name="Aggregation" class="Aggregation"> <parameter key="aggregation_attribute" value="vend"/> <parameter key="aggregation_function" value="sum"/> <parameter key="group_by_attribute" value="brand_fami"/> <parameter key="keep_example_set" value="false"/> </operator></operator>
