"The regression trees returned by the operators W-M5P and W-REPTree"
nicugeorgian
nicugeorgian New Altair Community Member
in the text version of the regression trees returned by W-M5P and W-REPTree: how should one read a tree branch (leaf) of the following form:
 attribute = RU,PK,TW,TR,IT <= 0.5 : : LM5 (798/81.241%)
Does
mean that attribute is not among the values RU,PK,TW,TR,IT?
LM5 is defined below the tree, and I assume it represents the value predicted (forecasted) for that leaf, correct?
What do the numbers 798 and 81.241% represent?
It seems to me that, in my example, attribute is treated as numerical although it's categorical (nominal). Is there a way to specify before the regression trees are run?
Many thanks for any idea!
Cheers,
Geo
  • IngoRM
    IngoRM New Altair Community Member
    Yes. As far as I remember this is the way how it is represented. You can get the idea if you look at the graph view.
    The first number is the number of training instances falling into this leaf and the second number is the root mean squared error of the linear model on these training examples divided by the global absolute deviation.
    As far as I know the nominal attributes are internally all converted into binary attributes which are then handled as numerical (hence the split value 0.5). I don't think that you can change this behavior since it one of the basic idea of the M5 algorithm.
    Cheers,
    Ingo
  • nicugeorgian
    Hi Ingo,
    thanks for the explanations.
    What do you exactly mean by
    ? Do you mean the global average absolute deviation defined as
    the average of all the absolute differences between every element of the whole sample (not only the instances falling into that leaf) and the mean of the whole sample set?
    Is there a document where I can see the exact definitions of the numbers in the tree's leaves?
    Thanks in advance!
    Cheers,
    Geo
  • IngoRM
    Yes.
    I took the information from the Weka source code and as far as I know there is no document describing this.
    Cheers,
    Ingo
  • BAMBAMBAM
    BAMBAMBAM New Altair Community Member
    Further questions on "text view" and "graph view" when viewing (tree) models :
    This is the output (RapidMiner version 4.4)
    W-REPTree
    REPTree
    Intensity < 0.98 : 0.23 (240/0.48) [144/0.49]
    Intensity >= 0.98 : -0.07 (1754/0.47) [853/0.48]
    Size of the tree : 3
    or to simplify, for each leaf we have
    Condition : A (B/C) [D/E]
    I'm guessing that:
    A is the label or predicted class
    B is the number of training samples found at this leaf and used to calculate the statistics
    C is the RMSE (root mean squared error) when 'A' is used as the prediction for the B samples,  divided by the global absolute deviation
    ... but I don't know what D or E are...
    Any help would be appreciated.
    Thanks!
  • land
    land New Altair Community Member
    I'm sorry, but I'm completely unfamiliar with the weka learners. Unlike Ingo I don't even have the source code to take a deeper look into. Did you search on the Weka Mailing list for informations about that?
    Greetings,
      Sebastian
  • radone
    radone New Altair Community Member
    The code is the following in the case of numeric values:
    0410:                        buffer.append(" : "
    0411:                                + Utils.doubleToString(classMean, 2));
    0412:                        double avgError = 0;
    0413:                        if (m_Distribution[1] > 0) {
    0414:                            avgError = m_Distribution[0] / m_Distribution[1];
    0415:                        }
    0416:                        buffer
    0417:                                .append(" ("
    0418:                                        + Utils.doubleToString(
    0419:                                                m_Distribution[1], 2) + "/"
    0420:                                        + Utils.doubleToString(avgError, 2)
    0421:                                        + ")");
    0422:                        avgError = 0;
    0423:                        if (m_HoldOutDist[0] > 0) {
    0424:                            avgError = m_HoldOutError / m_HoldOutDist[0];
    0425:                        }
    0426:                        buffer
    0427:                                .append(" ["
    0428:                                        + Utils.doubleToString(
    0429:                                                m_HoldOutDist[0], 2) + "/"
    0430:                                        + Utils.doubleToString(avgError, 2)
    0431:                                        + "]");
    and the following in the case of nominal values:
    0440:                        return " : "
    0441:                                + m_Info.classAttribute().value(maxIndex)
    0442:                                + " ("
    0443:                                + Utils.doubleToString(Utils
    0444:                                        .sum(m_Distribution), 2)
    0445:                                + "/"
    0446:                                + Utils
    0447:                                        .doubleToString(
    0448:                                                (Utils.sum(m_Distribution) - m_Distribution[maxIndex]),
    0449:                                                2)
    0450:                                + ")"
    0451:                                + " ["
    0452:                                + Utils.doubleToString(
    0453:                                        Utils.sum(m_HoldOutDist), 2)
    0454:                                + "/"
    0455:                                + Utils
    0456:                                        .doubleToString(
    0457:                                                (Utils.sum(m_HoldOutDist) - m_HoldOutDist[maxIndex]),
    0458:                                                2) + "]";
    I would be honest if anyone can understand the code.
