Simultaneous Model Output and Perofrmance Output
User: "atifshaikh4514"
New Altair Community Member
Updated by Jocelyn
Hallo,
First of all, thanx for this tool.
I have a problem I never faced before, I have the following operator chain:
    <operator name="DirectMailingExampleSetGenerator" class="DirectMailingExampleSetGenerator">
    <operator name="XValidation" class="XValidation" expanded="yes">
        <parameter key="keep_example_set" value="true"/>
        <parameter key="sampling_type" value="linear sampling"/>
        <operator name="MetaCost" class="MetaCost" expanded="yes">
            <parameter key="cost_matrix" value="[10.0 3.0 1.0;1.0 0.0 2.0;6.0 1.0 0.0]"/>
            <parameter key="sampling_with_replacement" value="false"/>
            <operator name="W-JRip" class="W-JRip">
        <operator name="OperatorChain" class="OperatorChain" expanded="yes">
            <operator name="ModelApplier" class="ModelApplier">
                <list key="application_parameters">
                </list>
                <parameter key="keep_model" value="true"/>
            <operator name="Performance" class="Performance">
I want to view each individual rule set generated by all iterations of JRip as well as the performance ouptut. Usually, without the performance output, a model simply outputs the rule sets without any explicit operator, but in this case, I am kinda stuck.
any ideas?
