I am going through the book Predictive Analytics and Data Mining by Vijay Kotu and Bala Deshpande. I am trying to run a file I downloaded from the books website
http://www.learnpredictiveanalytics.com/downloads.html. The rmp files are from a previous version. (I think one of the fifth versions) The file I'm using is 10_TimeS_10.2.2_simple_windowing_ts.rmp and it has a windowing operator in it. However, my version of Rapidminer is referring to it as a dummy operator.
When I try to run it I get a Process Failed Message that says, "The Dummy operator Windowing for Training (replacing series: windowing) cannot be executed. A dummy operator was inserted to replace an operator provided by a plug-in that is currently not installed. In order to execute this process, you must download the plugin."
What is the name of the plugin and where can I find it to get this to work? I'm having trouble coming up with anything. Thanks
