*** ERROR # 1461 *** in the input data: Card "WEIGHT" is not allowed for this subcase type.
User: "Michele Romano"
Altair Community Member
Updated by Michele Romano
As title, I'm trying to optimize a component with thermal loads on it.
The model works fine until I define the optimization parameters, which are one design variable, two responses (volumefrac and weightedcomp), as constraint the volume fraction and as object the weight minimization.
When I run the model I get:
Can someone help me with that, please ?
Michele
1 - 1 of 11
    User: "Adriano_Koga"
    Accepted Answer
    Updated by Adriano_Koga
    Hello, thank you for answering.
    I'm trying to make a typical topological optimization, removing the no needed material.
    After your suggestion, I tried Volumefrac as constraint and Thermal Compliance as objective but now I get:
      *** ERROR # 5031 ***
    Valid structural material is needed for optimization with structural responses
    Missing structural material ID = 1.
    I cannot find where the problem is.
    Thank you again
    Take care with 2 things:
    1) for strutcural optimization you need to define the MAT1 card for material + your MAT4 data.
    2) Transient loadcase is not allowed to this optimization. so you will be able to use only the steady-state loadcase. As objective you may want to use the thermal compliance for the steady state loadcase.
