How to Restart a simulation after certain number of timesteps in the HWCFD.Is there any video file available
At the bottom of the 'Launch AcuSolve' panel you have the 'Restart' with two arrows downwards. If you click on those arrows it will open the Restart settings. Check on the box next to 'Restart from previous solution' then supply the inputs for the available settings. It will then restart from the latest/last available restart output set from the indicated problem/run combination. Of course, this assumes there is an available restart output set from that indicated previous problem/run.
