I would like to install the Altair License Manager (ALM) through Ansible. Is there a way to install ALM without being prompted for answers?
you can use the 'silent' install, where you provide a config file for the installation.
It is mentioned in the License manager documentation, available when you download it.
you can use the 'silent' install, where you provide a config file for the installation. It is mentioned in the License manager documentation, available when you download it.
Thanks, I will have to look at the documentation closer. I missed it.
This is the document I am looking at.
https://www.altair.com/pdfs/pbsworks/PBSLicense2021.1.pdf
Can you point me to the Documentation you are referring to? It is not mentioned in this document.
Can you point me to the Documentation you are referring to? It is not mentioned in this document. https://www.altair.com/pdfs/pbsworks/PBSLicense2021.1.pdf
Sorry. I might have mislead you.
The documentation for the license manager can be found in Altair Connect.
But, i'm not sure if it allows you to perform a silent installation.
LM-X documentation shows silent mode, but not 100% sure if this is also valid for Altair's version of LMX.
https://docs.x-formation.com/display/LMX/Performing+a+silent+installation
Thanks Adriano, I was able to sort it out. But not using that method. I found some **** here:
https://vcdn.altair.com/secure/downloads/hw2021.1/documentation/AltairActivate_2021_1_Licensing_and_Installation_Guide.pdf?8eeea393ef108aed610d98fa47dc22e846302e022971de7d32463c72d759b712d27b1c1ac2c5c0c7435fd6616d37eb5233f464f9d99f35043c01e6a59e8acc1c9e1bdf2743c6090b58a4267b54762e117813fb564895974ad1ee1bcafb0bb319873412eb54f7fcd199ce700ba148e0734e7345d867cbc198da74207c1eac056bb5140feb257a7a8a7ab0b7f7371c83fd5781a2&filename=AltairActivate_2021_1_Licensing_and_Installation_Guide.pdf
This is what worked.
I was able to do a silent install of the altair license manager. Generate a properties file using the -r flag.bash altair_licensing_14.5.1.linux_x64.bin -r installer.properties (enter the responses)That creates a file installer.properties and puts it in the same directory as the .bin file. Then run:bash altair_licensing_14.5.1.linux_x64.bin -i silentIt will install with no input and start the license manager.
Thanks for you input, it nudged me in the right direction.
Thanks Adriano, I was able to sort it out. But not using that method. I found some **** here: https://vcdn.altair.com/secure/downloads/hw2021.1/documentation/AltairActivate_2021_1_Licensing_and_Installation_Guide.pdf?8eeea393ef108aed610d98fa47dc22e846302e022971de7d32463c72d759b712d27b1c1ac2c5c0c7435fd6616d37eb5233f464f9d99f35043c01e6a59e8acc1c9e1bdf2743c6090b58a4267b54762e117813fb564895974ad1ee1bcafb0bb319873412eb54f7fcd199ce700ba148e0734e7345d867cbc198da74207c1eac056bb5140feb257a7a8a7ab0b7f7371c83fd5781a2&filename=AltairActivate_2021_1_Licensing_and_Installation_Guide.pdf This is what worked. I was able to do a silent install of the altair license manager. Generate a properties file using the -r flag.bash altair_licensing_14.5.1.linux_x64.bin -r installer.properties (enter the responses)That creates a file installer.properties and puts it in the same directory as the .bin file. Then run:bash altair_licensing_14.5.1.linux_x64.bin -i silentIt will install with no input and start the license manager. Thanks for you input, it nudged me in the right direction.
Great!! Tks for sharing the solution!
