Introduction
A PC user running SAS who is trying to connect to Altair SLC on a mainframe has to use the telnet protocol. There is a section in the Altair SLC Communicate document entitled 'Authentication on z/OS using telnet'. A user creates a telnet script to launch Altair SLC on a mainframe via a CLIST and TSOWPS options of the form:
TYPE "altlib activate application " lf;
WAITFOR 'ENTER Application library', 5 seconds :fail;
TYPE "CLIST" lf;
WAITFOR "ENTER a single dataset", 5 seconds :fail;
TYPE "'WPS.V310.B31754.CLIST'" lf;
WAITFOR "READY", 5 seconds : fail;
type "TSOWPS OPTIONS('DMR WPSCOMPROTOCOL=SAS') TRACE" enter;
The relevant point here is that the WPSCOMPROTOCOL option tells the mainframe service that Altair SLC is expecting a SAS protocol from a PC otherwise it will be expecting a Altair SLC protocol.
Once the correct telnet login script has been created based on your actual system then the PC user would need to create a PC script of the form:
Print out the HOSTNAME of the local client machine
%PUT &SYSHOSTNAME;
filename rlink "/signon_mvs.txt";
Define the host machine that will execute remote code
%let host=;
Login into the remote server and launch remote Altair SLC ready to receive
signon host;
SUBMIT the following code between the rsubmit/endrsubmit block to host
rsubmit;
Print out the HOSTNAME of the remote server mainframe machine
%PUT &SYSHOSTNAME;
Print out the Default System Options for the Mainframe
PROC OPTIONS; RUN;
Print out the License features on the mainframe
PROC SETINIT; RUN;
Finished sending SAS language code to the mainframe in this block
endrsubmit;
SIGNOFF the host platform preventing further rsubmit's
signoff;
Tidy up - close the rlink filename
filename rlink clear;
