How to get RMS stress from random response analysis in optistruct? pls share the procedure for that.
If you are observing while ploting RMS stresses N/A.See attached screenshot.
Then make sure you select RMS over frequencies while plotting RMS stresses.
fem & h3d file for your reference OS-1325 tutorial.
Hi Rahul,
Thanks for your reply. But three RANDPS cards defined. Could you explain?
RANDPS for 3 loadstep combination in X, Y and Z.
