Altair WinProp: What are the available keyboard shortcuts for ProMan?
View the default shortcut keys available for ProMan for faster and easier operation.
Shortcut Key | Description |
Computation | |
F5 | Propagation: compute all |
Alt+F5 | Propagation: compute selected |
Ctrl+F5 | Propagation: compute modified |
F6 | Propagation including mobile station: compute all |
Alt+F6 | Propagation including mobile station: compute selected |
Shift+F6 | Propagation post-processing including Tx and Rx |
F7 | Network simulation: compute all |
Alt+F7 | Network simulation: compute selected |
File | |
Ctrl+N | New project |
Ctrl+O | Open project |
Ctrl+Shift+O | Open result |
Ctrl+D | Open database |
Ctrl+S | Save project |
Alt+Ctrl+S | Save project as |
Ctrl+Shift+S | Save result |
Alt+Ctrl+Shift+S | Save result as |
Ctrl+B | Export bitmap |
Alt+Ctrl+X | Export ASCII (all) |
Alt+Ctrl+O | Import data |
Alt+Ctrl+F4 | Close project |
Alt+F4 | Exit ProMan |
Display | |
Ctrl+R | Reset window |
Ctrl+Z | Zoom window |
Shift+Num + | Zoom in |
Shift+Num - | Zoom out |
Shift+Num * | Former zoom window |
Alt+M | Move window |
Ctrl+Shift+Num 8 | Move window North by 20% |
Ctrl+Shift+Num 2 | Move window South by 20% |
Ctrl+Shift+Num 6 | Move window East by 20% |
Ctrl+Shift+Num 4 | Move window West by 20% |
Ctrl+Num 8 | Move window North by 5% |
Ctrl+Num 2 | Move window South by 5% |
Ctrl+Num 6 | Move window East by 5% |
Ctrl+Num 4 | Move window West by 5% |
Alt+Num 8 | North |
Alt+Num 2 | South |
Alt+Num 6 | East |
Alt+Num 4 | West |
Ctrl+3 | 3D display |
F8 | Presentation plot |
Ctrl+W | Show all propagation paths for pixel on mouse move |
Ctrl+U | Show all propagation paths for pixel individually |
Ctrl+K | Delete all propagation paths on display |
Alt+Ctrl+I | Display Channel Impulse Response (CIR) |
Spacebar | Toggle selection of selected rays on the Propagation Paths dialog. |
Edit | |
Ctrl+E | Edit data |
Ctrl+F | Change-edit value |
Alt+Ctrl+E | Increase numbers of columns and lines |
Alt+Ctrl+R | Change resolution |
Alt+1 | Add data value (file, linear) |
Alt+2 | Add data value (file, delog, incoherent) |
Alt+Shift+2 | Add data value (file, delog, coherent) |
Alt+3 | Add data constant (linear) |
Alt+4 | Subtract data value (file, linear) |
Alt+5 | Subtract data value (file, delog, incoherent) |
Alt+Shift+5 | Subtract data value (file, delog, coherent) |
Alt+6 | Subtract data constant (linear) |
Alt+7 | Combine data: maximum value |
Alt+8 | Combine data: mean value |
Alt+9 | Combine data: minimum value |
Alt+Ctrl+E | Modify geometry of data: increase number of columns and lines |
Alt+Ctrl+R | Modify geometry of data: Change resolution |
Alt+Ctrl+F | Filter data in area |
Alt+Ctrl+M | Smooth data in area |
Alt+C | Change legend (continuous/discrete) |
Alt+F3 | Edit material properties |
Analysis | |
Alt+Ctrl+I | Channel Impulse Response |
Alt+Ctrl+L | Display values along a line: Draw line with mouse |
Alt+Ctrl+T | Display values along a line (from transmitter): Draw line with mouse |
Alt+Ctrl+A | Save values in ASCII-file |
Ctrl+G | Compute distance |
Ctrl+I | Information |
Settings | |
Shift+F4 | Open global settings |
F4 | Open local settings |
Shift+F8 | Load local settings |
Ctrl+F8 | Save local settings |
Ctrl+Shift+F8 | Save local settings as |
Alt+F8 | Copy local settings to all documents |
Window | |
Ctrl+F4 | Close window |
Alt+F10 | Cascade windows |
Alt+F11 | Tile windows (horizontally) |
Alt+Ctrl+F11 | Tile windows (vertically) |
Alt+F12 | Arrange symbols |
General | |
F1 | Open the WinProp User Guide |
At+F1 | About ProMan |
