Hi ,
I am working on modal analysis of rotor system in optistruct. I have queries regarding constraints. Pls find the following image which shows rotor assembly with bearing. I need to allow rotation free of rotor and shaft at bearing locations. How to give constraints at bearing locations ? Using RBE2 or any other options are there in Optistruct?
Thanks
Arul
