View the default shortcut keys available for WallMan for faster and easier operation.
Shortcut Key
File
Ctrl+N
New database
Ctrl+T
New project
Ctrl+O
Open database
CTrl+R
Open project
Ctrl+S
Save database
Ctrl+J
Save project
Ctrl+P
Print
Edit
Ctrl+Z
Undo
Ctrl+Y
Redo
Ctrl+X
Cut
Ctrl+C
Copy
Ctrl+V
Paste
Ctrl+Shift+V
Paste at original coordinate
Del
Delete
Ctrl+A
Select all objects
Shift+F10
Scale all objects
Shift+F9
Renumber all objects
Ctrl+Shift+S
Simplify database
Ctrl+K
Check database
Ctrl+Shift+M
Materials
Ctrl+Shift+F
Floors
Shift+F7
Default values
Objects
F10
Select single object (mouse)
Ctrl+F
Select single object (number)
F6
Select multiple objects (area)
Alt+F10
Select multiple objects (material)
Shift+F6
Edit properties
Shift+F8
Edit material properties
Alt+M
Move selected objects
F7
Enter polygonal object
F8
Enter rectangular
F9
Enter orthogonal object
Alt+F7
Enter virtual buildings
Alt+F9
Enter courtyards or towers
Alt+F6
Import indoor database
Projection
Shift+F1
X-Y plane
Shift+F2
X-Z plane
Shift+F3
Y-Z plane
Shift+F4
3D view
Display
Alt+Shift+Z
Zoom in
Alt+Z
Zoom out
F11
Zoom window
Ctrl+F11
Zoom factor
F12
Mouse pan and zoom
Ctrl+F12
Fit to screen
Alt+R
Update display (redraw)
Ctrl+F10
Goto position
Ctrl+G
Grid
Ctrl+Shift+C
Colorize materials
Preprocessing
F3
Edit preprocessing parameters
Alt+D
Draw rectangular pre-processing area
Alt+Shift+D
Draw polygonal pre-processing area
Alt+A
Show pre-processing areas
F5
Compute pre-processing project
Ctrl+F5
Compute current project
F1
Open the WinProp User Guide
At+F1
About WallMan
