How to apply displacement as load in linear static analysis in Optistruct? and apply the same in local co-ordinate system?
Rgds,
Arul
Hi Arul,
You can create a local system and assign node(s) to this local system
Now using DAREA you can apply enforced displacement. Go to Analysis>> Constraints>> change load type to DAREA and apply on the node(s)
Thanks Prakash
