Hi ,
Need clarification regarding FRF analysis using Optistruct . What is the need of taking PHASE response in the tutorial - OS-T: 1300 Direct Frequency Response Analysis of a Flat Plate ??
Then what is the use of below responses ??/
Arul
Please refer attached screenshot from help.
Use below link to request free eBook on Dynamic analysis using OptiStruct.
https://altairuniversity.com/free-ebook-learn-dynamic-analysis-with-altair-optistruct/
Hi Rahul,
Thanks. What is the use of Phase Plot in dynamic analysis?
Hi Arul,
Phase plots/ tell you the direct connection between applied load and response.
Hi Prakash,
Thanks
