On some multi-CPU Windows systems it could happen in some cases that not all of the CPUs (cores) are used by Feko in a parallel run. This could be observed even though the machines file and number of requested processes (cores) specify that all available cores should be used.
For example, on a machine with 4 CPUs and 32 cores each, it could be observed that no more than 64 cores are used even though a total of 128 processes (cores) where requested.
 In cases such as the above, perform the following steps:
 - Set-up Feko to use MS-MPI.
  - Set the environment variable MPIEXEC_AFFINITY=2
  - Also set the environment variable MPIEXEC_AFFINITY_AUTO=1
