Can I install Altair Analytics Workbench 2023, 2024, and/or 2025 in parallel on my Windows PC?
Yes. Bear in mind that Altair SLC and Analytics Workbench are both required and are installed from separate MSIs.
You will probably need to edit the file "workbench.ini" and add the line:
-Dwpshome=C:\Program Files\Altair\SLC\2024
(or 2023, or 2025)
to ensure the expected SLC appears as the 'Local Server' when you run Workbench.
