Can we create interior cavity of a vehicle by using SPH/ALE ?
Hi guys, I could see that in HM14.0 , there is an option of cavity mesher. Is there any tutorial availbale for generating and modelling cavity using that option?
Hi guys,
But that option in HM14 also coarsen the existing mesh and generate Cavity. My query is that the cavity can be represented by SPH/ALE ?
Hi @Kaushmat
Can you please refer to RD-E: 0600 Fuel Tank and RD-E: 5000 INIVOL and Fluid Structure Interaction (Drop Container) (Modelled with ALE)
and Example 22 with SPH and if this helps?
